Ron_Nielson
Jul 26, 2015Explorer
dougrainer wrote:
But, you still have a 120 volt supply problem. UNLESS, you have an aftermarket 120 element or an Element that is NOT the correct wattage for your refer. That is why I would want to know the amp draw of the element. Doug
Doug
The 120V heater is original to the refrigerator. When tested independent of the control board, the refer works just fine at ~114 volts. So I am fairly certain that the problem is not (primarily) the heater, and that's why I think it IS the control board.
Just to satisfy those who say 'replace the thermistor', I have one on order and will test again with a new thermistor. As pointed out, it's only $15 (and less work than replacing the board) and a board is $100. I'll wait to buy the control board until I've tested with the new thermistor, just to be sure.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 27, 2026
