KenS999's avatar
KenS999
Norcold Refrigerator Carbon Buildup on Flame Probe
Hello I have a Norcold N306RM8 in my 2017 Forest River Cherokee Wolf Pup. Seem to be plagued by carbon boogers building up on the flame probe running on LP. What causes them? Replaced the burner tube/orifice about a year ago. Recently replaced New Flame probe as it was burned up. Today replaced burner tube / orifice again with a new one to see if that corrects the issue. It seems when there is carbon build up on flame probe the refrigerator does not cool as effectively while running on LP.
Thank you,
Ken
  • "Make sure your flame is not yellow, lastly adjust your flame fuel screw if everything else is clear."
    Thanks. Flame is blue. Where is this fuel screw that you mentioned located at? Burner tube/orifice is a single piece, and brand new. Ken
  • Id checked the gas pressure too. If the pressure is low, the btu input will also be low but it will also draw in less primary air. A dust free, clean orifice is also important, but that doesn’t sound like it would be a problem in your case. Be sure the burner is super clean, so nothing restricts the primary air intake.
    If it still soots after all that cleaning Id figure out a way to get more primary air… by hook or by crook, there are ways. Craig
  • You are running rich, not enough oxygen. Check the full length of the burner tube and chimney. Make sure it is clear of wasp nest and spider nest. Make sure your flame is not yellow, lastly adjust your flame fuel screw if everything else is clear.
