RRTom wrote:
I have a norcold refrigerator. Unable to supply the model number right now.
I had the motor home a/c units set at 75 degrees. Outside temperature was 72 degrees. When I went into the motor home at 7:30 AM, the temperature in the refrigerator was 39 degrees. I am operating it on electric. Is this in the "normal range"?
What 'temp setting' are you using? (1-9)
'3' then 39*F is within range
'5' then 39*F and ambient is 72*F---then cooling unit should be able to go lower then 39*F
'9' then you have REAL cooling issues.....thermistor, door seals, heat transfer, obstructed cooling unit tubing etc.
39*F under what circumstances????
Lot more involved then JUST if temp is within range!
