imgoin4it wrote:
Instructions on two different brands of refrigerators, , Frigidaire and GE, both say set the temperature of the refer at 37 and the freezer at o. I think they understand the temperatures as well as the appliances they manufacture.
Agreed with enthusiasm
In the tropics shelf life is critical. I "try" to keep things as cold as possible. The refrigerator does not actually damage produce or fruit at 32 degrees. Actual item temp. Sensitive stuff is kept nearer the door. I have a Pabst fan on 24/7
The freezer is kept at - 10F but if outside temps exceed 90°F 24 volt amp hours start climbing too rapidly. I ease the setting to zero.
I use amp hour meters on both the standing 18 CF freezer and refrigerator. They were added late 2017 They manage data like crazy. I had the freezer spray foamed 2 - 3" on sides, bottom and rear.
In the reefer mayo lasts longer at 35 than it does at 40.
Tiny fans aid cooling of both condensers. My son in law drove to an American enclave and bought seven used panels off lady who was bailing out. Quicksilver now has 11 panels making it autonomous. The 7 panels are alongside not mounted on the roof until I get home.
