BFL13
Apr 30, 2014Explorer II
The Centurion may not have a relay. You get 12v ok from converter, and your battery is charged, so your problem is between battery and DC dist panel.
The flare up and then dead symptom could mean some sort of bad connection. Look for the connections at the battery post, the battery catastrophic fuse, the battery disconnect switch, and the battery wire lug on the DC dist panel.
