- MEXICOWANDERERExplorerBut it should have been made clearer in the first place. :)
- red31Explorer
MEXICOWANDERER wrote:
The word HOURS, AMP HOURS is missing from the above two posts.
as it should be - MEXICOWANDERERExplorerPianotuna, exactly right.
Larger shunts naturally widen the resolution band. The + - % error yadda.
The BORG has a pair of 50 ampere shunts. One digital the other analog 50-amp capacity. Kinda wish I waited and used an amp hour meter or better yet a kWh meter.
I am chasing down a USB input, A to D converter with kWh graph plotting. Expandable scale one minute resolution of all three components, amperage, voltage, and ampere hour accumulations. PC powered analysis. I am not sure what software program they use. It's of Indian / Malaysian origin. I like the minute by minute data points. Bi-directional polarity - MrWizardModeratorDon
the Ebay store where i ordered the 200amp version
has 400 amp and 600 amp versions
basically its the same meter with different programming and a much larger shunt for the larger loads - pianotunaNomad IIIAs near as I can tell about 1 hour at 242 amps. But I do not own an amp-hour counter.
My point is, that with a medium to large inverter one needs a meter that would read up to 300 amps. My "high" discharge rate is 276 amps. - MEXICOWANDERERExplorerTo Be Or Not To Be...
HOURS!
That is the question
242 amps X 12-hours = 2,904 ampere hours. Have a 3-axle battery trailer, do you?
:) ;) - pianotunaNomad III242 amps continuous load. I heat electrically and have a Magnum hybrid inverter--so when the power went off the inverter kicked in to keep the RV warm.
- MrWizardModerator242 amps peak ?
Or
242 amp hrs total ? - pianotunaNomad IIIThe other day power went out to the entire city. I ended up drawing 242 amps according to the Magnum remote, so I think I do not need yet another meter.
- rjsurferExplorerI ordered one as well.
I'm sure I'll be back here needing some help on the install :-)
Ron W.
Having RV issues? Connect with others who have been in your shoes.24,335 PostsLatest Activity: Nov 13, 2025
