ktmrfs
Dec 02, 2022Explorer III
Bobbo wrote:
The closer the charge controller is to the batteries, the more efficient it is. Distance from the PV (solar panel) is less critical.
true for MPPT controllers, somewhat true for PWM controllers.
With a PWM controller if the battery is deeply discharged it lets full panel current to the battery and voltage is regulated by the battery and internal resistance. Where the controller is really doesn't have much if any effect on charge current. As the battery nears full charge it switches to a duty cycle square wave, and here is where distance matters since now voltage drop between the controller output and battery will limit charge current and increase charge time needed for a full charge.
For a MPPT controller it sets the voltage at the output of the controller during the entire charge so voltage drop in the line working against battery voltage and internal resistance= low charge rate. And since MPPT controller output current is higher than input current during initial charge, voltage drop between the controller and battery can be more limiting than between the panel and controller. Especially true if the input to the controller is a series string of panels. So for a MPPT controller it is important to have the controller as close as possible to the batteries.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
