brisath's avatar
brisath
Not finding flasher fuse 2005 Gulfstream
Flashers not working. Brake lights not working. Turn signals weren't either but found and replaced fuse so those work but can't locate any fuses or relays for the others and manual doesn't list them.
RV is 2005 class A Gulfsteam Sunseeker with 8.1 Chevy Workhorse chassis.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Under the hood. Dead center, eye level for my 6' person, is a black box NO LABELS
    Latches on each side of the box.. Fuse layout on inside of cover
  • j-d's avatar
    j-d
    Explorer II
    Just an idle thought, but I'll toss it out since you haven't had a specific reply yet.
    The coach builder often uses the "Trailer" wiring, fuses, etc. when they put an RV body onto a bare chassis. This could lead you to a different group of fuses, maybe even in a different fuse panel. Have you tested for power at your Trailer Tow socket? Probably powered from same group of fuses as rear turn signals, brake and marker lights. And possibly a common connection point down on the chassis.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
