Old-Biscuit
Jan 18, 2014Explorer III
Check your converter DC output at the terminals on converter where battery cables connect........should be at least 13.4V DC.
Without batty hooked up the converter is supplying all the DC demand.
The 120V AC side is sagging or dropping out so converter DC output drops and DC control circuit fails.
You have a loose/bad connection on 120VAC side and your converter MAY be failing also.
Good luck on the search.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: May 23, 2026
