StirCrazy
Apr 12, 2022Moderator
pianotuna wrote:
Stir crazy,
I have no way of knowing what the battery chemistry is. It is not specified in the owners manual.
I'm only providing information for others. LiFePo4 are useless for me.
I believe they are wonderful batteries for temperatures above freezing.
so your providing information for other on somthing you have not used or don't know if you used, and yet the information you like to provide is from older chemestry lightium batteries which don't share the same properties as newer versions.... just think about that for a second...
as for tempatrue outside temprature has absolutly nothing to do with useing or charging LiFePO4 batteries, it is the battery temprature that matters, they are no use to you becasue ou refuse to put them in a conditioned space or use a heating system for them. for others who camp at -40 they might just be fine.
It just seams to me that because you don't want to put in the work to make them suitable, which is fine, you think that nobody should find them suitable and spread half truths or total BS about them in your never ending attack posts..
I have one of my rv's set up on LFP now and I think its wonderfull, and I would have no issue of camping at -35 except my old small furnace wouldnt keep up and theres hardly any insulation in the camper :B when I do up the 5th wheel that will be the test as I will camp in -15 to -20 in that if I have to.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
