wa8yxm
Nov 17, 2014Explorer III
One other questions: You said you plugged in at home.
is this an outlet you have used often for RV or is it a new one?
Might be a 240 volt issue .... Many electricians see a TT-30 and wire it for 240 volts. Many RVers see a welder or dryer or air compressor 240 volt and think "TT-30" (Depending on the outlet type).
I had one Moose Lodge governor ask me if I had tried the 60 amp outlet they had (I had not even seen it, I had however, seen the dual ganged circuit breakers (two pair, both 60 amp) so I already knew it was 240 volt.. Finally found it the next day, they use it for an industrial fryer.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
