myredracer's avatar
myredracer
Explorer II
Oct 16, 2015
Now have 3 tires @ 2 seasons old & one new
Just had to replace a damaged tire on our TT that has 2 seasons of use and is 1.5 years old. Was planning to replace them at about 5 years old. So if I left it as is, along with a never used spare, would I replace all 4 tires at the 5 year old point? Or would it have been better to replace the damaged tire with the never-used spare and use the new tire as a spare? Not sure if it makes sense to replace the one tire that is only 3 years old at the 5 year point? Or does everyone just do a "batch" replacement of 4 tires at the 5 year point and forget about it? (Forgetting about total mileage at that point.)
FWIW, our TT had over 2,000 miles put on the tires from Indiana to the dealer on the west coast by the delivery guy so they were already partly used when we got the TT. Have maybe around 8K miles on the TT so far so about 10K total.
  • I'm surprised with all the mods you made to the trailer that you would still have factory ST tires on it.
  • Old-Biscuit wrote:
    I do 5 yrs. on my FW tires.
    As suggested....new tire becomes spare
    'Mechanical damage'
    Passenger/curbside front axle tire?
    Curbs will cause sidewall damage
    Many years ago when I went from TT to FW found out FW tracks 'inside.
    Whacked a few 'obstacles' when making right hand turns at first...then got used to 'wide turns' :B
    An upper shock mount came loose and was flopping around against the tire and cut a bad groove on the sidewall (luckily did not cause a blowout or worse). Really bad welding job by a frame & suspension shop sub-contracted by our dealer. Have had all 4 shock mounts repaired now and are out the cost of a tire as well. The other 3 remaining shock mounts peeled right off with a crowbar and those would have eventually failed too.
  • myredracer wrote:
    dclark1946 wrote:
    What kind of damage to the tire? Hit something or blowout?
    I am assuming these are ST tires. If so, 3 seasons is all you should count on.
    Dick
    Yes, ST tires. Mechanical damage, rather not get into detail. Shop stated on receipt for me: "damaged beyond repair - scrap".
    I thought some say you can do up to 5 years depending on mileage and if they're taken care of. I'm picky about doing all the right stuff including religious checking of air pressure before each leg of a trip.
    According to Discount Tire, in 3 years 30% of an ST tire strength is gone. Five years is the absolute maximum life with 3 years being more conservative.
    Dick
    Dick
    'Mechanical damage'
    Dick
  • What kind of damage to the tire? Hit something or blowout?
    Dick
  • j-d, thanks for the input. Yes, that makes good sense. The new tire is from March 2015 and the others from Aug. 2013. I shoulda thought about this before and will have to get the tires swapped so that the new one becomes the spare. Not a big deal except the shop is at the other end of town.
  • j-d's avatar
    j-d
    Explorer II
    Given what you've got I think I would:
    1. Run on that New Tire
    2. Mount the Never-Used Spare
    3. Put the WORST of the one on the ground to SPARE - by Date Code if nothing else - The Spare won't be much more serviceable after Five Years as Never Used than it will be IF Used. The rubber still ages, even if not visibly.
    4. When you replace the set, if the tire you just bought is less than 5-YOA, consider it as a spare, otherwise replace them all. You don't want to lose a tire with 100 to go and install a spare that blows at 50.
    About Date Codes - Find them and jot them down. You're likely to find out that the TIRES are much older than your RV. The coach warranty starts at Date Purchased. The tire warranty might, too, but they are still the AGE of their Codes. Don't hesitate to ask for fresh date codes when you buy tires, and don't hesitate to refuse aging ones.
    My experiences:
    1. Good-looking old tire on daughter's college car. Looked nearly new but tread separated. Didn't damage the car, but triggered the fuel cutoff. She could change the tire but couldn't find the cutoff reset. Car had to be towed.
    2. Bought a new van, ran original four tires till they needed replacement. Put the Never Used Spare on along with an AGED New Tire like it. Those tires were 8-10-YOA at that point and wore out in half the miles the originals did. Rubber just wasn't fresh. At least neither blew out.
    3. Bought a used Class C with unknown tires. Planned to buy new, drove to work (so I could take it from there to the tire shop) before the sun heated the road surface. Tire blew on the way to work! Tore up the fender skirt, knocked sewer dumps an fender skin loose. SEVEN new tires that day!
    Remember, a blowout of ONE tire will cost more in coach repair that a SET of new tires...
Having RV issues? Connect with others who have been in your shoes.24,360 PostsLatest Activity: Feb 13, 2026
