- racer4ExplorerYes, you can format the flash drive on another computer.
- Wife_nHubbyExplorerComputer is trying to repair itself and I am being given options to fix it and have chosen to back up files first. It showas 14.4g of files to be backed up. Since computer is in the "fix it" mode I can't format the flash drive. Any suggestions? Can I format the flash on a different computer and then use that flash on my computer?
- hbillsmithExplorerShipped from the factory it is most likely FAT32. You can easily change that by reformatting using Windows to do it. In the format dialog just select format type NTFS. The bad news is 32gb is most likely too small a drive.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
