Matt_Colie
Nov 25, 2018Explorer II
I was running a durability lab in the early 80's, What was real good was GM (a client at the time was changing from SAE to Metric. So, things that screwed into production major castings would still be SAE until the casting was revised. Everything else was Metric. Sounds easy - Right?
But there were two problems:
FEAD (Front Engine Accessory Drive) stuff often connected to other FEAD stuff and a block or head. Where it connected to a major casting it was "probably" SAE. Where it tied to another bracket, it was Metric. Unless the head casting was a new design (which was happening a lot because they were trying to reduce weight), then it might be metric.
Then there was the supplier issue. When they called for an 8mm fastener and did not specify, it was a toss-up if the supplied fastener was DIN or JIS and the pitches were different.
That has fortunately been solved by an SAE edict that describes all the fasteners as laid out ISO.
As it is for me right now, our coach is only SAE (being OLD), but I carry a set of tools for ISO too. That is just so I can help someone that may need it.
Matt
Matt
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
