ktmrfs
Nov 27, 2018Explorer III
Big Katuna wrote:
Metric may not be better but it’s way easier for most people to add 25mm and 12mm than “1-5/16 and “7/8.
exactly. it isn't that one is "more accurate" than the other, (it isn't) it's that the metric system is much easier to do the math.
and have the units come out in a standard format and one base measurement unit. No do you want inches/ft/yards,miles or ounces/lbs etc.
and that many conversions are real easy.
No 8lbs/gallon 16 oz/lb, 12 inches/ft 3ft/yard ****
1 liter of water (1000cc) = 1KG, (1000g) 1 cu meter=1000KG ("metric ton)
same with distance. easy to calculate
and when you get to complex physics problems it makes the world much easier.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
