CA_Traveler
May 31, 2014Explorer III
Both our 7.5 and 10K gens were on slides and both were in the front which helps with load balancing. You'll probably need heavier slides and if you're very lucky the space will be adequate. Due to the weight I'm not sure lowering/raising the unit is practical.
The 7.5 should be adequate for the new refer. But electric range type thinking might put you in the 12K gen league.
