Old-Biscuit
Dec 12, 2016Explorer III
RVER wrote:
I have a adjunct to this question. I also have a fifthwheel and pull it with a Chevy 2500HD diesel with Alison transmission. I can not get it to say it is in tow haul or O/D off with using the button on the shift handle IF it is in D but if in 3 Both of them work. I am not sure they are not working in D but that it does not light up indicating that it is that mode of tow haul or O/D off which is the same button. IS THAT WEIRD or what? I have put it in tow haul while in 3 and then shifted to D and I think it works the tow haul. I like tow haul mostly for the way it uses the tranny for engine braking when pulling the fifthwheel.
Per the OWNERS MANUAL for 2003 Chevy 2500HD
Automatic transmission equipped vehicles are provided with a button at the end of the shift lever which when pressed enables tow/haul. When the button is pressed, a light on the instrument panel will illuminate to indicate that tow/haul has been selected. Tow/haul may be turned off by pressing the button again, at which time the indicator light on the instrument panel will turn off. The vehicle will automatically turn off tow/haul every time it is started.
If you have an automatic transmission, you can tow in DRIVE (D). You may want to shift the transmission to THIRD (3) or, if necessary, a lower gear selection if the transmission shifts too often (e.g., under heavy loads and/or hilly conditions).
So the little 'trailer icon' should come on when you select Tow/Haul
(1st push of button on end of shift lever)
O/D DISABLE if you push button again
Push it again and back to Drive O/D
Just give me the dang manual LINK
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 19, 2026
