TucsonJim's avatar
TucsonJim
Explorer II
Mar 14, 2017
Odd Brake Shoe Failure. Any Ideas?
Since I'm retired, I like to keep busy and help family and friends with RV maintenance items from time to time. This time, I volunteered to inspect the brakes on my son's 12 year old pop up and repack the bearings for him. He had the brakes replaced about six years ago, and has maybe put 3000 miles on it during that time.
When I inspected the brakes, there were cracks running parallel to both rear brake shoes. I've seen brake shoes crack laterally before, but never radially like the ones pictured here:
I inspected the drums and they were within size tolerance and there were no hot spots indicated. Since they were okay, I don't think heat was the issue.
I've ordered replacement brake assemblies and will be installing them as soon as they arrive. BTW, the assemblies I ordered were self adjusting and not the cheap manual adjusting brakes he had.
Have any of you ever seen a similar failure? If so, is there a likely cause?
As a side note, I'm also going to replace his bearings, races and the cheap brake wire connectors you can see pictured in the photos.
Jim
  • Yes, sort of. About 4 or 5 years ago I had to replace the pads on the E450, there were lines like that irregular shape and in the thickness, causing big chunks of pad material to flake off, pads were near new thickness, no signs of overheating but had to be replaced. Mechanic said that it was a defect or contaminate in Ford OEM pad material. Also about 25 years ago, we had to replace the pads on the Ford Ranger, big holes in the pad material, mechanic then said that it was not uncommon, again a contaminate, causing sections to dissipate.
    Ken
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
