Airstreamer67
Sep 13, 2013Explorer
I bring a 1500 watt electric heater and use it first if I'm with 120 volt service. If the heater needs help or I don't have 120 volt service, the gas heater is used.
If the gas heater is factory supplied, it should be vented to the outside and not need any additional venting.
How long the LP tank will last depending on trailer size, insulation, how high the desired inside temperature will be, the size of the heater, and such.
In a warm southern climate, you probably won't need to turn on the gas heater very much.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
