time2roll
Sep 13, 2013Nomad
I bring my 1200w electric radiator if temps will be close to freezing or below. Primarily to save some propane and reduce cycling of the main furnace.
30# of propane goes faster as the tempurature drops. Seems to increase exponentially as temps drop below 20F. 30# will go at least a week if you stay above freezing. Check your automatic regulator every morning for the signal to fill... assumes you have two tanks. Try to spot a propane supplier as you roll into a new space.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
