mlts22
Sep 13, 2013Explorer II
westend wrote:
I've taught myself to crack open a vent at night if a propane appliance is used. Your OEM furnace is vented to the exterior but one can't be too careful.
To be on the safe side, I always use at least two CO detectors (preferably three), one having a readout of how much CO is in the air. That way, if some crazy thing happens, the CO alarms would go off before there was enough in the air to be dangerous.
If I were using a Mr. Buddy heater, I definitely would be cracking open a vent (likely two so a little bit of air goes in and gets exhausted out to ensure plenty of fresh air) because the heater uses up oxygen in the rig and the fact that burning propane makes a lot of water vapor. However, with those factors in mind, as well as making sure it won't catch anything on fire, the Mr. Buddy heaters can do a great job at heating up a RV without needing electricity or making major inroads on propane.
Having RV issues? Connect with others who have been in your shoes.24,379 PostsLatest Activity: Apr 14, 2026
