JiminDenver
Aug 17, 2013Explorer II
BFL13 wrote:
I think all you can get with PWM is the Isc of the panel, whatever its voltage is. So to get that 13-14a from your 230w "24v" panel, you still need your MPPT controller AFAIK.
However, I don't have a clue about it getting over Isc (of 8a) when it is "in PWM mode" if it can. Perhaps it is still in MPPT, and not really in PWM when it is "in PWM" but the MPPT isn't doing much? Not a clue.
BFL
You have to remember the altitude I camp at. 10.000 ft has the opposite effect on my panels as it does on my generator. Even in Denver with the smog, I could see above the rated output of either of my panels in a short circuit test, then again that rating comes from sea level. Up in the clear air at 9-10,000 ft the ISC jumped 50%.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
