12thgenusa
Aug 17, 2013Explorer
Here is the efficiency chart for the Rogue 3024 along with a quote from the manual.
"Typical efficiencies range from 95-97% under most conditions. As a rule of thumb, higher efficiency occurs as PV voltage increases (which causes a corresponding decrease in current for a given amount of power), and as the difference between PV and battery voltage decreases."
I usually see at or above 96% as several examples from the display show.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
