JiminDenver
Aug 17, 2013Explorer II
KJINTF wrote:
Mex
Jimin
If you could measure the array voltage array current and at the same time the battery voltage and battery current - we would love to see the numbers with a discharged and a mostly full battery
Even if the machine is in the high 80% efficiency range for the $15.00 or so it sounds like it could be a good deal
I can do that with my MS TS 60 and report the numbers is anyone is interested
I can do that but it may be a while before I get back up in the hills. We should have been there now but work got in the way. Should have been up there 2 weeks ago and again work made a mess of the week.
I have the controller and the 220w panel here at the house. It wont produce the same numbers but at least I can run a few test when I get time.
A deeply discharged battery will require running the 12v fridge again and I'll have to make sure I'll have the weather to run the system first. Can't be having any half charged batteries now can we. :)
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
