KJINTF
Sep 06, 2013Explorer
A quick simple test would be to measure the array voltage and the battery voltage while in operation. I assume your 130watt panel has about 17Voc and maybe 15Vmp depending on the light/heat conditions. If you measure the array voltage it should be close to 15 volt mark while the battery should be charging at a lower voltage. If there is no difference then ...... after all it was only $20.00
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
