BFL13
Sep 11, 2013Explorer II
No more results for now. Only thing missing is what it does when the batt reaches full (which is kind of important! :) )
Never quite got there in my test. It should drop to Float or just quit charging until batt voltage falls to a low set point and then resume charging and keep doing that to maintain the battery.
The manual mentions a LED going to off when "charging stops" or some such wording, so suspect it will do it that way.
O&S, you could check that yourself easily enough if you have a full battery to put it on. I won't have full batts like that for another couple weeks at least.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
