tlecronierExplorerJun 03, 2013Oil drain plug rusted in and strippedWhat I thought would be an easy job has turned in to a nightmare. I went to change the oil in my Onan QD 7500 Generator and the oil drain plug would not budge. I used penetrating oil and heat. After t...Show More
OldF__tExplorerJun 03, 2013You might want to look into MightyVac products. You can vacuum most any kind of fluid from anything.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
Related ContentHouse battery drainRust!!!Hot water tank drain hole is strippedPower DrainGrey water tank won't drain completely
