jayco302fk
Jun 04, 2013Explorer
If you can access it and if the plug is metal not aluminum you can weld a new nut right on top of te striped plug and then use a 6 point socket to back it out. I have used this trick on many striped and rusted bolts and its always worked.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
