azrving
Feb 18, 2015Explorer
Chris Bryant wrote:
I was waiting for one of the generator guys to chime in, but I'll swear there is a reed valve in there somewhere in the crankcase breather that can get stuck.
I could well be wrong though- that's not my forte...
Yes, the crankcase breather is often a flutter type "reed" plate and it could be his problem.
It let's the crankcase get rid of any blowby and it's directed to the air cleaner housing so it doesn't go out to the atmosphere. It's actually an emission control device as compared to the old small engines that had the little breather hose hanging off the side of the valve chamber cover or the draft tubes that hung down off car and truck engines.
If you had a ton of blow by it could push excessive oil but the op didn't mention poor performance or smoking bad so that's not the problem.
This manual may be close to your model but dont take it as gospel as I dont know the actual model numbers off your engine/gen.
It shows a breather set up on page 8.8 and 10 .2
Manual
before I tore it apart I would search the manual or other resources to try to find out what a manometer reading would be for that engine. The manometer would measure the vac or slight negative pressure in the crankcase. If the flutter/reed valve is stuck and not working properly you may not get a correct manometer reading and possibly push oil into the hose and filter area.
If the reed valve was to stick closed and not vent the crankcase, a positive pressure would build in the crankcase because of normal amounts of blowby and start pushing oil out of the engine where ever it can. Sometimes past crankshaft seals and sump pan gaskets and rings.
This video explains some of it. it's not the best but....
Crankcase venting
OP, has anything been done lately? Has anything different happened?
The last small engine I worked on that had a problem like that was a Honda 4 stroke walk behind snow blower. The last guy to work on it had installed the crankcase breather hose onto the wrong plastic fitting on the air filter housing. This created a build up of pressure in the crankcase and it started leaking like crazy around the crankshaft seal and sump cover gasket.
The one before that was a Kawasaki vertical shaft engine on a new JD lawn tractor. It was still smoking after being torn apart and rerung TWICE. I wasn't working on it but being one of those curious jobs to everyone in the shop we were all looking at it. The valve cover was off so I used a long screwdriver and put in down the passage way in the head and block that leads to the valve chamber breather area. The head was drilled for it but the block had never been drilled at the factory. It doesn't happen often with small engines but crankcase ventilation problems do happen.
So with all that said you need to know what's going on with the crankcase/breather. Maybe someone else has an answer. There is always something else that may be the problem.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
