GATJcampers
Feb 18, 2015Explorer
oil in air filter for generator
I was camping in the desert with my generator (onan microquiet 4000 with 224 hours)when it suddenly died. I have a toyhauler and it was about 90 degrees and it wasn't under a large load. So i opened the compartment everything appeared to be fine. I figured I would check the air filter, so I cracked the filter housing wing nut and bam out pours some oil.? all told about 1/4 to 1/2 cup came out. the filter had oil on it, not a lot but some. cleaned it all up and it ran fine. Why was there so much oil in the filter housing? any ideas? There is a breather tube from the valve cover to the air filter housing but is it supposed to put that much oil out? any ideas? Thanks in advance
