PapPappy
Oct 04, 2013Explorer
Geez, at those temps, you may not even want any oil:S
Only kidding.
You may want to pull the oil out when it's not running....to keep it warm (the way Bush Pilots used to drain the oil from their planes up in Alaska), then add it just before you run it.
A PITA for sure, but at least you'd know it was gonna start, and be lubricated properly.
I'd think, if you did that, you could probably use the normal weight oil....but agree with Dave, you may want to check with Mfgr.
To cold for me:B
Another thought....why say you have come to the dark side.....you just left it, now you have light!:)
Only kidding.
To cold for me:B
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
