- Keep the controller close to the battery for best results.
+1 for SolarBLVD.com
If you want guidance on choosing components.... give some additional info on what you expect from solar.
Is this the kit? http://gpelectric.com/products/solar-extreme - hmknightncExplorerUse as short a run of wire as possible from the solar controller to the batteries. For a TT this generally means mounting the controller in the front pass through then battery wires down through floor and up to battery box. Your TT converter location is not important to the solar system (they are seperate systems that both charge the baterry(s).
- pianotunaNomad IIIHi,
Kit's are not usually a bargain. Solar should be wired to the battery, not to the converter. - mena661ExplorerWire direct to batteries. Since you're in SoCal, go over to Norco and visit Solarblvd and/or visit their website.
Having RV issues? Connect with others who have been in your shoes.24,321 PostsLatest Activity: Sep 21, 2025
