- KpackpackkelleyExplorer II
Kpackpackkelley wrote:
I misunderstood that question was thinking about shore power 20 amp receptacle. I better drink some more coffe and wake up.
When I'm at home I plug into a 20 amp receptacle to keep batteries charged . I have ran the ac before but you can't have anything else on. - wilanddijExplorerMy Onan 5500 pulls 12VDC from the batteries for startup. When its running, it supplies 120VAC, it does not pull power from any circuit. Is this a serious question?
- dave17352Explorer III must be thick headed because I don't understand the question. Could somebody explain please.
KATOOM wrote:
Does anyone run their 5500 Onan on a 20 amp plug? The Onan manual I have states the running amps well under 20 but I dont know what the start-up amps would be, if its even different.
This post does not make any sense. Period. Doug- TEXASExplorerStart up amps are from your load. Not the generator. So you need to know how much load you have.
- KpackpackkelleyExplorer IIWhen I'm at home I plug into a 20 amp receptacle to keep batteries charged . I have ran the ac before but you can't have anything else on.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
