144Grayling's avatar
144Grayling
Explorer II
Nov 09, 2023
Ok to run shore power without battery?
I have a 2007 Komfort trailer with a WFCO ultra distribution panel model WF8955an with a 3 stage converter. Lately the fan in the panel has started running for hours at a time. I checked the battery and it is boiling HOT. We don’t travel, the trailer is plugged into shore power 100% of the time. Is there any problem with removing the battery and just having the 12v lights and bath fan run off the converter?
  • Obviously, something is wrong with the battery charger...so best not to use it at all until it can be repaired or replaced.
  • I added a battery disconnect and use that for winter storage but left the TT plugged into shore power so I can still use the lights and radio. Just yesterday I plugged in a portable electric heater and took a nap in there. Need the light’s because I put reflectix in all the windows, retains the heat a little better and makes it much darker in there. My batteries are LiFePO4 so no float voltage isn’t a big deal.
  • I'd check the voltage the converter is producing, particularly if you are going to run it without a battery. I know of at least one case where a WFCO converter failed & produced 21V, destroying a pair of AGM batteries. High voltage can damage your lighting & 12V appliances...
