MEXICOWANDERER's avatar
Aug 07, 2015
OK! Uncle! I Give Up! Switch Sourcing Frustration
  • Must have minimum 1/2" threaded shaft for thick panel
  • 120 VAC 10 amp rated
  • Double pole
  • 4Positions or more
  • No, I do not have thirty dollars to spend on a switch.
Would like a nice pointer dial. And the switch must have an extra pole to serve for no connection - OFF.
Dual pole is because many outlets (receptacles) down here are wired backward.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
