MEXICOWANDERER
Aug 08, 2015Explorer
OFF
FLOAT MAINTAIN ONLY
CHARGER only TIMED BY WIND UP TIMER
CHARGER TIMED THEN DEFAULT TO FLOAT until switched to off.
Daily use I want Jesus to use charger only. Not disconnect leads when float can spark. The float only is for my Lifelines. Charger timed then default to float is for obvious use. Kid has a 6th grade education is intelligent as all get-out but this isn't the simplist charger to deal with. I want this swtch to be a No Touchee switch. Plug in the unit with the switch pre-set for his boat 27 flooded marine battery. I'll take the 7.39 seconds to dial-in 14.8 volts before he takes it down to his 26' "lancha". He is a diver and only travels for 2-3 miles. Bright lights aboard for night lobster diving. Little by little I'll teach him to Top Charge and Equalize. An LTH Ciclando Profundo group 27 costs eqvt of 172 dollars down here. Plus a 100-mile drive.
The only way I come up with a reasonably price switch is a 10- amp rotary dual pole five position long necked switch. Blue Seas has one for 271-dollars. I'll go get it and toss it into the glove compartment of the Bentley.
FLOAT MAINTAIN ONLY
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
