- MEXICOWANDERERExplorerThank you Vixen21 - yes indeedy - thanks to Mr Wizard the switches will be on their way to Chula Vista manana. I like the two index pegs! They'll keep the switch from rotating when twisting the "rooster beak" knob. The power supply agreement fell apart. The guy wanted $18 to USPS the units from Oregon. Checked USPS rates online and rate came out to six dollars and change. He didn't want to part with 33-dollars in pumped up shipping charges.
I've got a lot of small packages waiting for me next month in Chula Vista. Lots of surge suppression components. Found 2-amp Pico fuses for the avalanche diodes and MOVs. I just cannot believe companies do not use redundant components in hyper expensive equipment. Pianotuna and Niner are both promised genuine spike clampers with gas discharge tube protection against nearby lightning. Whole rig protection. - Vixen21ExplorerI think Mex said he was ordering the switch (in another thread)
- MrWizardModeratorBump
- MEXICOWANDERERExplorerStill no joy on the switch. There is a dearth of 10-amp rotary switches. Even 300-dollar shore power changeovers have only three positions.
- MrWizardModerator
MEXICOWANDERER wrote:
I want to post this separately. Thank you Mr Wizard
your welcome.. glad to be of help - NinerBikesExplorerMexicowanderer, you should see if someone would donate you an Unlocked Verizon Galaxy S4. It comes with a bigger battery, bettery chip, it can be used in International mode, both GSM and CDMA technology by phone companies, and it has a 2 amp charger and charges in an hour to hour and a half, in full. Get a extended run fat back battery for it, 7200mah, and you should have no problems getting through the day with one charge. It also has a bigger screen.
A rooted phone with a custom Kernel and Custom hacked ROM would be even better.
Go look up your phone model on XDAdeveloper
Learn about Android.
S2 extended run batteries - NaioExplorer IIIf you are having to recharge your phone multiple times daily you might try a new phone battery. They are usually 99 cents including shipping on ebay. Plus then you have a spare.
I am glad Niner sent you a phone :). - MEXICOWANDERERExplorerI want to post this separately. Thank you Mr Wizard
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
