StirCrazy
Feb 14, 2023Moderator
RLS7201 wrote:
If the Air Admittance Vent doesn't fix your issue. There is another possible reason for the stink inside your RV. When going down the road, the inside of the RV goes into a negative pressure, caused by the large flat area in the rear. This allows the pressure differential to induce a stink in the RV. I replace the caps on the roof vents with sanitary Ts, to put the tanks into the same pressure as the inside of our MH. Or you can purchase the rotating roof vents. Rotating roof vents.
Richard
I have to take another look but I have never seen an air atmittance valve for the bathroom or the kitchen sink for that matter.. my thinking has been that maybe the vent is plugged or not venting right, but the smell is only pulled into the bathroom not the rest of the camper where I would expect it if that was the issue
