StirCrazy
Feb 15, 2023Moderator
Ok so I went out and looked all over the camper there are no air atmittance valves in the camper at all, no places that sugest they were ever used.
Like vents in home plumbing I believe you only have to add a vent if your sink is more than a spicific distance away from the stack.
in my camper the kitchen sink has about 2.5 feet of pipe (if that) then it is in the grey water tank, the other end of the grey water tank is about the same distance from the bathroom sink.
so I guess im back to the toilet seal... its a older camper maybe it is hardened up. I'll change that out then this spring we will find out if it worked.
in the mean times, if you think of anything else I should check let me know.
Steve
Steve
