partsman01's avatar
partsman01
Okay boys, what did he do wrong?
So on this GMC K2500HD I bought the owner had a LED back up light installed, they used those things you put on the wires and then squeeze shut with pliers and it saves you time as it is quick, anyway, found out when backing up light is on, but as soon as I touch the brake pedal it goes out, appears he hooked up to one yellow and one light green wire going into bumper 7 way plug in, I think it should hooked to yellow, but the other should be ground, should it not?
Thanks
Bill
