j-d
Apr 02, 2015Explorer II
This eTrailer Link
shows the center pin as Backup while the diagram above calls it AUX.
On the linked diagram, Yellow looks like what should have been connected (Called "reverse lights) to the Hot side of the LED, and its Ground wire should go to White/Ground. If it's LED, polarity matters. The light's ground should be on White.
If the LED is connected to the 7-way, make sure the wiring isn't damaged or loose.
Like RoyB said, most likely whatever color is to the Center Pin for the Hot, and Ground to White, Terminal #1, or any other good Ground.
Those pinch things are called Scotch-Locks.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
