darsben1
Sep 09, 2017Explorer
gatorcq wrote:
Diesel do not have spark plugs.
I think he was answering my question about the outlets
Quiet Pack has a generator inside and uses an electronic governor to maintain voltage and frequency. So, no Inverter / Charger.
Did the Gen set run the loses power / or did it not have power when you started it? Did you see if you have a ATS, automatic transfer switch?
Since you stated your batteries are not charging is this on shore power also or just generator? Have you tried shore power?
Have you checked the circuit breaker on the gen set?
The bigger power is, not knowing what Rv you have, Inverter / Charger installed in the Rv. So, there is nothing most of us can do, because we cannot do any research on your Rv. No you can logon to IRV2 and search the motorhome specific forums.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
