RobertL0
May 16, 2015Explorer
Ok, thanks for your reply. I just initiated a draw down. My converter has 5 feet of number 6 wire (I think) to the batteries.
I'll do some memo writing with my Bogart 2030-RV before I start a charge cycle, and monitor it.
My converter has a build date of Oct 2014. I thought they rectified that problem of not going to bulk mode in these newer converters.
Regards
Regards
AH64ID wrote:RobertL0 wrote:
How old was your converter?
They where both new to me. I had one for 4 seasons and never saw boost and the seccond didn't make it a season before I ditched it.
As it was mentioned they need to see the voltage drop at the converter for a set period of time to trigger boost. This is nearly impossible on OE wiring, or any wiring longer than a few feet. They should either monitor voltage pre charge (like PD does) or use current. The method that the WFCO uses doesnt work in application.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
