wa8yxm
Oct 30, 2018Explorer III
HOw I do it.. TUrn off DC (House battery disconnect) this disabled the Fridge. Furnace, Water heater and all the "Sparkey" stuff in the RV alt: Turn off all the "Sparkey stuff".. Also kill the generator if running.
Next.. TURN OFF tank outlet valve.. Hook up hose (using proper adapter) to the inlet. Open the Visual Overflow Indicator Valve (sometimes called the "Spitter valve") and start pumping till it spits. Stop pump. close valve. releive pressure in adapter and unhook recap and optional open tank valve. Or pull away and open tank valve.. I pull away BEFORE I restore 12 volts to all the "Sparkey Stuff".
NOTE.. Save for turning off all the "Sparkey" Stuff (12 volt disconnect) and the adapter for the fill port.. No different than filling a 20 pound luggable.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
