Gdetrailer
Jun 05, 2022Explorer III
RV junk.
Not worthy of commercial food truck service.
You need to connect with place that constructs commercial food trucks and find out what they use, most likely is going to cost substantially more than RV water heaters and the commercial grade manufacturers will pass all health codes for food service.
High altitude service can be problematic, RV water heaters often have issues with high altitudes. Commercial units should be configurable for that type of service.
HERE is one food truck builder you could try contacting to find out what they use.
You also should reach out to your local food safety inspector folks as they are the ones that will need to build to and satisfy.
Food service is not a place to skimp or cut corners.
