RobG's avatar
RobG
On-Demand Water Heater? Worth it?
My original water heater is going bad and my extended warranty is going to replace it. The shop doing the work says they can put in an on-demand (RV) unit for the same cost, so I'm considering it. What do you think? Anybody have experience with these? Figured I should ask in case they don't work as well as the residential units. My stock heater is 12 gallons, but it takes an hour and a half to heat up (used to take 40) plus the tank is rusting out too. But it'd be nice to have unlimited hot water (relative to the amount of freshwater I have, plus gray tank space -- assuming not being in a park). I live in the thing fulltime so it'd be really nice.
Thoughts?
Rob
  • My new Atwood 6 gallon regular water heater has an 18 gallon an hour recovery feature. It doesn't take that long to get the water steaming hot either, probably 15 minutes or less. It's almost like an "instant-hot" once the tank is initially hot.
    WoodGlue
