TucsonJim
Oct 24, 2013Explorer II
I would assume you have an On Board Diagnostics port under your dashboard. If so, you can pick up a resonably priced OBD scanner and get the engine code. Once you have that, you can really narrow down the problem. Some auto parts stores will check the code for you at no charge.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
