HpyKmpr1962
Oct 25, 2013Explorer
I would lean towards a worn or pinched wire to the od button on the gear shift selector handle. Most of the symptoms you described happen on our work trucks and that was the cause.
Any good shop should be able to help with diagnosis.
It is a DIY project to change, with patience.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
