skipnchar
Oct 25, 2013Explorer
One trick about replacing suspect fuses is to remove another 15 amp fuse where you have no issues to put in the tranny slot and put the 30 amp where you don't have an issue. Safer than putting oversized in a suspect slot.
Good luck / Skip
Good luck / Skip
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
