MEXICOWANDERER
Dec 18, 2020Explorer
Thank you for you patience with me on this. I paid $400 back in 1980 for a set of Onan repair manuals that had Cummins suffix chapters. 50 years ago I was forced to learn generator prime movers because they were attached to generators.
Kato under 1 MW has disappeared LIMA is gone now to 500KW is all garbage like Stamford. Sealed primary excitation and voltage regulators. Unrepairable. The old Onan stator crank saturated field 4.0 -- 6.5 were a kick to work on and use it like automotive sealed modules that cost 10x their worth is the norm. I go back to the days of Rocking Beam mechanical AC Generators. When the regs quit I had to wind 22 ohms of 12 gauge nichrome on a lathe to use as a ballast. Some of the old gensets were nasty with 90 volt 13 amp field current.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 29, 2026
